download not completeing
I have downloaded 96.6 % of an audio file,and although it is active I cannot access the missing pieces.Is there anything I can do to get these missing pieces
Look at your seeds/peers column. it will list the number of connected Seed/Peers followed by total number of [seeds/peers]. If there are no seeds, then you have little chance of completing the download.
Sometimes BitComet can complete such a download from connections to LTseed peers, which are outside the normal bittorrent swarm, or from emule sources, if these options are enabled, but if you have no seeds present and your download has stalled, then this isn’t likely to happen. You can continue to run the task and it is possible a seed or LTseed will appear, but it might be faster to simply find another source for the files you want.
Another option is to go to the tracker/website where you got the torrent and post a request for a reseed.
If there are seeds present, then there could be more technical problems involved.
Look at the HEALTH column for the task. If it’s below 100%, it means there are no complete copies of the torrent between all of the members of the swarm and unless that changes, a torrent cannot complete.
