1.36
20mb down/2mb up cable internet from twc
**3) **Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port?
linksys wrt120n wireless, ports are forwarded, WAN is green
5) What version of Windows, Firewall and Antivirus do you use? Is your Windows 32 bit or 64 bit?
win7 home premium 64bit sp1
avg 2013 business edition
ive done speed tests at both speedtest.net and using the twc site and both come out at an average of between 18mb-20mb download and 2 mb upload
**llas for my issue, its come up the past few days where i cannot get any torrent speeds over 500ish kb/s. it could be for a single torrent that can get up to 500, if i turn it off and start another it might get up to 500 as well, but i run them both together or add a few more,the total of all of them stays around 500kb/sec. this is well short of the 2000kb/sec average im used to. **
**ive tried reinstalling bitcomet, ive tried using utorrent (hate it), new drivers **, wired/wireless connections…nothing seems to get the speed back up. if i go and direct download something i get 2000-2500kb/s speeds consistant with what im used to. now granted twc is a crap company and im always having issues, like having to restart cable modem, its just weird that bitcomet seems to be throttled at around 500-600kb/sec while everything else tells me connections are fine. its not related to specific torrents either ive tried with many files of all different sizes and seeders/peer amounts.
im at a loss of what to do or try next.
