I am started with new PC and sorry forgot to measure and set proper speeds. Now I do this and results are:measured download speed 491,1 kB/s and set speed 400 kB/s
" upload " 31,19 " " " " 25 " .
If You can tell me is thise settins OK or not?
Thank You in advance!
Regards
your use of commas and quotes make this post difficult to understand.
Please post results of your speedtest and we’ll recommend proper settings.
TuuS, keep in mind that in Europe and most of Asia, a decimal is written in the form of a “comma”, whereas in N. America and in some parts of the UK a “period” is used, instead…
(eg.) 1.99 € = 1,99 €
…and, to add further confusion between cultures, the “comma” is also written in the top (as opposed to the bottom) half… such as…
(eg:) 1’99 €
Neat, huh?
Do You read my massage 5-th May? I just write measured data in my town and setins values. Jast tell me if I do that correctly or not, and what to do!
Regards!
Sorry! Measured speeds are 491 and 31 kB/s. I set 400 and 25 kB/s. First are downloads and seconds are upload figures.
Regards
Well, the math on this is very simple. You usually limit the upload speed at 80% of the tested upload capacity, so you’ll need to multiply with 0.8 whatever upload speed you measured.
Just make sure that the test site gives you the results in KB/s or MB/s not in Kb/s or Mb/s or else you’ll have to manually transform speeds from b (bits) to B (bytes) before multiplying by 0.8, since BitComet measures speeds in bytes multiples.
To get a rough quick transformation you’ll have to divide by 8 the tested upload speed (if it’s given in b/s) to get it in B/s.
You do not mandatorily need to limit your download bandwidth, unless you want to reserve some bandwidth for other applications which you will use in parallel with BitComet.
