Hi there all just shifted from another client… to BitComet only because of DHT… that client also has DHT but I was having problems… well…
in bitcomet the downloaded sdata it show is more and the percentage of completion is less… .. .??? what is this..!!! EXAMPLE… i have 700 Mb of a File… the Downloaded data is 115 Mb… and Done% is 10… any suggestions…
You’re going to get some rubbish data when downloading. If it’s really bad then either someone using Azureus 2.4.0.0 or the swarm is being posioned.
Use a good firewall to protect your PC. Norton & Zonealarm are not good firewalls, the XP SP-2 actually is a good firewall.
And try Peer Guardian 2, it will block known bad IP address. During install use these three lists of theirs: p2p, ads, & spyware. Don’t bock education, you don’t want to block people who are using their high speed college lans that can upload to you. Also, don’t use bluetack’s lists. Their’s are bloated and the guys who make them are over paranoid noobs.
