Downloaded piece #635 failed
log:
2011.02.01 03:41:32 Downloaded piece #635 failed in hash check, 2048 KB dropped.
this error is appearing repeatedly( the above line is from logs),and lot of the download is wasted…what is it? what can i do about it to solve.
i use:-
win XP SP3
BitComet 1.25
like these,
2011-02-01 05:50:42 Downloaded piece #2134 failed in hash check, 2048 KB dropped.
2011-02-01 05:54:59 Downloaded piece #1991 failed in hash check, 2048 KB dropped.
2011-02-01 05:55:23 Downloaded piece #2234 failed in hash check, 2048 KB dropped.
2011-02-01 05:56:04 Downloaded piece #1990 failed in hash check, 2048 KB dropped.
2011-02-01 05:56:59 Downloaded piece #2263 failed in hash check, 2048 KB dropped.
2011-02-01 05:57:18 Downloaded piece #2043 failed in hash check, 2048 KB dropped.
there are over 60+ errors in the logs.
i have added a screen shot, take a look at the logs.
i just installed
BC 1.26 still the problem persists.
Your answer lies in this Wiki FAQ topic: What is “rubbish data” and why am I downloading so much of it?
TUUS, there seems to be a problem either with this guy’s upload limit or a bug with the forum’s lack of enforcing that limit for some file types (namely, BMP). He uploaded 9 BMP files each 1MB in size with no problem.
ya…thanks i will install peer guardian and check.
I don’t think this is the problem with my router because this is the only task which has this problem.
i will install PG and reply again.
thank you.
You may instead want to find another torrent with the same material.
I installed peer Guardian 2 and kept for downloading for 6hrs, the no. of such dropped pieces(“rubbish data”) has reduced(not completely stopped though) which is a good thing…but if i see the log or history of peer guardian it says no IPs blocked.So, i dont know if the reason behind the reduction in no. of dropped pieces is peer guardian,but today no. of dropped pieces have reduced and i think i will continue to use peer guardian.
If peer guardian says you have no blocked IPs, that is because you haven’t added any block lists, so it is infact doing nothing at all.
When you add block lists, be careful not to add lists simply because they exist, many are available that will block good IP addresses, like educational institutions. Many university internet connections seed torrents from high speed servers and you would be making connections to them impossible if you block educational IP addresses (for example). Also, the anti p2p lists usually come in two formats, one has verified hostile IP addresses, and the other which is often referred to as the “paranoid” list will block every IP address a company owns even if only one of that companies IP addresses are hostile.
The level 1 anti p2p list should be all you need. You might also want to block government IPs if you live in an area where it’s legal for government to monitor your internet usage.
Also note that some of these lists will block servers used by bitcomet to log into comet ID, and to check your listening port.
Wiz, our forum settings allow “member” user group to have a total max upload limit of 10mb. There is also a Server max limit imposed by php of 2mb per file.
Other then the fact that this guy exhausted his entire allotment in one topic, I see now problem here.
I do think he should be instructed to save his files as .jpg or .png, and these attachments should be removed if they no longer serve a purpose so he can upload other files if/when needed.
