downloading bitcomet
hey all,
I might just be an idiot, but I can not download the bitcomet client from www.bitcomet.com
I tried to official mirrors as well with no luck.
I have no problems from other sites (www.download.com for instance)
Is this a problem for anyone else?
No, it isn’t. What happens when you try?
http://download.bitcomet.com/achive/BitComet_0.70_setup.exe
If you’re using IE or Opera just right click and select “save target as.”
I’m trying to dl the program too. But all I’m getting is connection timed out.
Hmm, I downloaded a copy of 0.70 seven hours ago. I guessing the server is overloaded at the moment.
If you want you can email me and I’ll just send you the file. B)
