Downloading Files Other Than Torrents Instantly Routed To Bitcomet
Since downloading Bitcomet all files I download are routed to the Bitcomet program. I only want to download Torrent files with Bitcomet. How do I change my settings so that per se RAR or mp3 file from Rapid Share is downloaded without Bitcomet? Thanks in advance for your attention to this question.
What browser do you use?
The options for controlling this are on the Options–>Integration page.
This issue was avoidable during the setup of BitComet. When you install software, you should pay attention to the options you are given in the setup process. It’s a good idea to ALWAYS select “advanced” or “custom” setup instead of the default or “usual”, or “express” setup – even if you don’t change a thing, accepting the default options at every stage, you’ll at least know what is being affected. You had the option to have BitComet handle, or not handle other downloads. You took the default option, which is “yes”.
As Wiz says, you can change that in the options of your particular browser, but you need to pay attention to what installers are doing lest you find more ‘surprise’ changes like this.
I would check to see how many tools bars you have installed in IE.
Actually, I was referring to the BitComet options dialog. On the *Integration *page there are options allowing you to make BC release the handles for default downloader and to uninstall the browser extensions it installs by default.
when the file is asking to be downloaded just say no refuse and then another window opens if you have chrome then starts imidiately in firefox is asking you again and lust if you use downloader is a matter of integration us the modman said
