downloading order
is there a way to move a torrent up or down in order of when to download. If I have a list of torrents ready to download and i am downloading 1 or 2 at a time and i add a new torrent and want to down load it right away is there a way to move it up the list with out having to stop all the others in the list and then restarting them after the one i wanted to move up in order has started. Not sure if I explained that properly.
Select the torrent, then use the “move up/move down” arrows to move the task up or down. If they aren’t active click on the top of the “name” column until they become active.
thank you for your help that will save a ton of time.
Thank you I’d been trying to figure that one out for the past hour!
Solved six years ago :wink:
