My download speed is only 10kb/s and im on 512 broadband. is this the normal speed for my internet connection. if its not does anyone know how to make it go faster.
-Make sure all your hardware (routers/NICs/computers) have up to date firmware/drivers and are set up properly
-Also make sure your computing environment is clean (no bad drivers, conflicting software, virus, trojans, etc)
-Try to sign up or get invited to a private tracker and try to get torrents that have lots of seeds and peers
-Avoid ISPs that block or throttle file-sharing (if you can)
check this link to configure your BitComet settings correctly: http://forums.bitcomet.com/index.php?showtopic=533
