You don’t need to make an upgrade in order for this to occur. It suffices that you shutdown Windows while BC is still exiting and this issue may occur.
It’s actually a matter of not being able to write on the disk the tasklist file.
As you can read in the FAQ link, it’s quite easy to fix if you use a version newer than v.1.18.
