Hi I am running on windows xp prof, my isp is bt broadband with a max of 8mb which varies from
5991.2 Kbps
734.2 K bytes/sec
to
3702.4 Kbps
453.7 K bytes/sec (ZDNET) and my isp speed tester average is 3000 kilo bits per second (Kbps)
I am reasonably happy with as the average around this area is 5.5mbs but the problem is when i come to download anything my download rate is very poor ranging from 20kbps to 100kbps when i should be running atleast trebble that.
my adaptor is dell wireless 1450 dual-band (802.11 a/b/g) usb2.0 adaptor, when setting up port forwarding i lookin at what my router was actually recieving and it was getting all 8mbs which i was happy to see.
i just reformatted this computer that i am running now and has spyware/spybots, the only firewall i have is the one that is on my router which is netgear DG834G (which i have port forwarded for the programs that i am d/l with)
TCP/IP Analyze results are;
TCP properties for IP = xxx.xxx.xxx.xxx ()
Browser/OS = Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
Notes: Read the Analyzer FAQ if the above is not your IP address.
TCP options string = 0204058a0103030301010402
MTU = 1458
MTU is not fully optimized for broadband. Consider increasing your MTU to 1500 for better throughput. If you are using a router, it could be limiting your MTU regardless of Registry settings.
MSS = 1418
Maximum useful data in each packet = 1418, which equals MSS.
Default TCP Receive Window (RWIN) = 514728
RWIN Scaling (RFC1323) = 3 bits (scale factor of 6)
Unscaled TCP Receive Window = 64341
For optimum performance, consider changing RWIN to a multiple of MSS.
Other RWIN values that might work well with your current MTU/MSS:
521824 (MSS x 46 * scale factor of 8)
260912 (MSS x 46 * scale factor of 4)
130456 (MSS x 46 * scale factor of 2)
65228 (MSS x 46)
bandwidth * delay product (Note this is not a speed test):
Your TCP Window limits you to: 20589.12 kbps (2573.64 KBytes/s) @ 200ms
Your TCP Window limits you to: 8235.648 kbps (1029.456 KBytes/s) @ 500ms
MTU Discovery (RFC1191) = ON
Time to live left = 50 hops
TTL value is ok.
Timestamps (RFC1323) = OFF
Selective Acknowledgements (RFC2018) = ON
IP type of service field (RFC1349) = 00000000 (0)
i used the optimizer and set it to optimal settings.
ANY SUGGESTIONS WOULD BE REALLY HELPFUL AS I AM GOING OUT OF MY BRAINS
TRYING TO FIGURE OUT THE IS GOING ON!!! TY also suggestions on how to get my test results a lil bit more stable and consistant would be a great help to! (hope i haven’t missed nething out)
