downloads with IP blockers
I recently started using Expat Shield to mask my IP but bitcomet won’t doanload. It will load the torrent and will start the download as soon as I turn Expat off. It did the same thing with Hide My IP. What can I do? Is there a better IP blocker that works better with Bitcomet?
You cannot expect someone to send you data if you don’t tell them the correct address to send it. The only way you can be anonymous when using p2p is if you rent a computer in an area of the world that doesn’t provide their customers info to other countries, then you would need to connect to the internet through that computer, or run your torrent client on that computer.
