dvd burning
hi all i have downloaded all the series of the sopranos,each series as approx 12 episodes at approx 1hr each
i want to burn these to dvdr 4.7gb but dont know what programme to use i would like to try and fit at least 4
episodes to each disc,can anybody suggest a good programme and if poss a brief overview of how to use
thanks nikki
Hi, The easiest programme to use is Nero, It will automatically shrink the programmes to fit onto a 4.7 DVDR, but remember the more episodes you put onto one disc the gradual loss of A1 quality will occur.Try if they are 1hr episodes to stick to 4 per disc.
Hope this helps…!!
