DVD recorder
Hey guys i need to buy a DVD recorder i was just wondering if i record something of tv will i be able to put it on my computer and edit it in a movie making program or does this have to be done some other way? If so how?
One more question if i do have to buy a DVD recorder what should i be looking for in it?
Cheers
–Max–
hey, I just bought two of them for $59 each USD. I got the last, but I know where you can get them deleivered for $68 each usa delivery, other areas will be more I’m sure. TheTechGeek.com
This model will play divx .avi files, and record dvd video. I is made by lite on, and has mixed reviews at videohelp.com
however, since many people thought it was resonable value at $200, then you can’t really beat the deal.
It’s down side is no Svideo jacks mostly.
There are much better decks, but nothing close to that price.
I also have a Go video vhs/dvd recorder, which works well.
as for editing, you can edit any video with the right software, and with a dvdrw disc, you can edit out commercials right on the deck, then copy to a dvdr if you like.
ps videohelp.com reviews most models for you
Thanks heaps mate!! :slight_smile:
