Using BC v1.23 and the eMule plug-in of the same name (most recent) on Vista through a router on an ADSL2+ service,
When I installed this new plug-in, the window came up and I was able to use eMule to get some other files that bitcomet can’t fill in, from other places by separate searches. Now after re-starting once (due to some other system instabilities) eMule window will not come up when I tick “show plugin window” under “eMule plugin” in “tools”… The file area does appear to be being updated by additions of new file entities labelled with the clock time, and the process is extant. Not much change to the progress of the files I wanted, as far as I can tell, but I can’t unless they actually get completed anyway. What am I doing wrong? :huh: Or is it just Vista??? :lol: Thanks, Jarrahdale.
