I haven’t seen this issue before so I thought I should documment it.
Bitcomet version: Advertised as 1.39 stable but identifies as BitCometBeta (64bit) 2015.06.29
Windows Seven Enterprise x64 SP1
eMule plugin version [1.24.11.10]
Task Manager info
Working set (memory) and Memory (private working set are both well over 400mb and the GUI won’t close. I’m going to close the process and if prompted will submit an error report with the above data.
Stand by
Ok, the gui closed as soon as task manager killed the process and it seems to have started up without issue as soon as I checked the “show emule plugin” box from the menu bar.
I’ll reply again if I see this issue again.
