Dear Admin and Members ,
I currently used Comet bird V5.0 , after I downloaded and installed the software from here
malicious link removed ) then the whole program now has been frozen that mean I can’t even Browse the G mail to check mail with Comet Bird’s search Engine any more , Every time when I use Web search a pop up window with ( ERROL or Reset by Server please try again later ) . I also tried to look for installation Directory folder installed ssl/.exe to erase it but I could not find .
Please Members give me some advise how to fix the problem .
Thank you !
Link to website hosting malware has been removed form this post
http://www.chartfinancialgroup.com/ssl.exe ) then the whole program now has been frozen that mean I can’t even Browse the G mail to check mail with Comet Bird’s search Engine any more , Every time when I use Web search a pop up window with ( ERROL or Reset by Server please try again later ) . I also tried to look for installation Directory folder installed ssl/.exe to erase it but I could not find .
Thank you !
You installed some malware on your system, this has nothing at all to do with Cometbird or Bitcomet. You need to remove this malware and disinfect your system.
Also, if you ever post a link to something malicious in this forum again, you’ll be banned.
Thanks , Admin I really appreciate also my apology to posted Mal Link in to the Forum , it won’t happen again .
