this was one error message which appeared… could someone kindly help me out…
i am quite a bit of a nube.
“A sharing violation occured while accesing …(where the torrent was and still is)…”
all you brilliant technical people out there… this desparate fellow needs you right now…
so someone kindly… HELP ME!!!
This error usually occures when two programs are trying to use the same file/s
I suggest shutting down your programs, rebooting your computer, and see if it reoccures.
The cause of this is impossible to diagnose without a LOT more information.
Please do as I recommended, and report.
If problem still is present, try to close all unneeded applications.
thanks mr suspect. it worked. you have restored my faith in the Lords of the torrents.
I am very pleased that this problem is resolved…
suspect
