Hello,
I am here to suggest a feature that should be added on to BitComet.
The suggestion is:
I would like to be able to schedule specific torrents on BitComet, instead of all of them downloading when the schedule is set.
Else, if that is too hard, an option for when you exit BitComet, the torrents still running, will be turned back on when BitComet is re-opened (Because then I can use Windows’ “Schedueled Tasks” program).
Thanks.
