Feedback on 0.79
Okay, I understand that 0.79 is a new core or something, so I’m not gonna try to rag on it. I was somewhat disappointed that I replaced a 0.70 install with this new version, as two features I use are gone and there’s now a whole ton of “Comet Zone” cruft in the interface.
So I’m going to make two statements here
First is features.
The two things that have been taken away from me are :
  1. The ability to choose to start more downloads than the “Max simultaneous download tasks number:” value. In 0.70 I could have 10 torrents queued. Bitcomet would automagically start the first 3, and if I chose to, i could click on others and click “start” and they’d get going. So I could have a maximum tasks value of 3, and left alone Bitcomet would never run more tasks than that, but I could chose to run more. This no longer works.
  2. The “stop” conditions don’t seem to work. I started 4 torrents from VERY healthy swarms this morning, and when I got back they were all uploading with very high ratios (like 4.0). Normally I’m set to stop seeding at a share ratio of 130%.
Second is this “Comet Zone” business.
I use Bitcomet as a Bittorrent client. I use it because it has features the “stock” Bittorrent client does not, like multiple torrents from within a single instance of a single program. I get my torrents from other sites, that specialize in the content I am interested in.
I do NOT do so with Internet Explorer, either the browser itself of embedded into another application.
I do NOT use Bitcomet as a general-purpose P2P application, and trying to turn it into such is very quickly going to scare me away from the program. Provided the extra cruft can be easily turned off and does not burden the program, I can probably put up with any amount of “dumb-user-ification” you want to put in the program, but PLEASE keep it as a lean, mean, torrenting machine.
Do keep in mind that 0.79 is not a stable version, and that features have been coming and going with every version since 0.71, so nobody is too sure what will or won’t make it into the next stable one. But you can pretty much figure that existing features like task queueing will be there and will work before they’ll deem it stable. In the meantime though, don’t count on them.
I’ll add that the Stop Seeding conditions don’t seem to be working for me, either. They are stopping too soon, actually.
Plus, after fully downloading a torrent’s files, in some cases the “ratio” column is not moving above 0.0 - even after I’ve noted that the individual properties page for that torrent shows it has uploaded a significant percentage of what was downloaded by then.
Should this be reported in the “bugs” portion of the forum?
  • ooofest
Please feel free to report in the bugs section.
Posting a screenshot is a good idea, to be sure we fully understand the bug your reporting.
Well mine was a totaly different problem wid 0.79, i clicked any damn button and bitcomet tools window used to open. so i had to download 0.70, this one is a pretty stable one.
put on bit comet 0.70 version , shedule for "off " and i very hapy
everithing ok with version 0.70 dl is ok ,and i not put last version ,think
