Files Not Renaming themselves When Completed
Like the name says it. Sometimes it will rename properly, sometimes it will stay .bc! forever
I am not new to bitcomet and am ranked 190,XXX with my passport login.
Running Windows 7 Ultimate
Bitcomet 1.16
port correctly forwarded (good speed too)
did not have this problem with windows xp, same version everything, same computer.
any advice?
Does the task show 100%?
Does it start seeding?
What percentages shows the Files tab?
Try to perform a manual hash-check on the tasks in question and enable bitttorrent.hash_check_on_finished in Options–>Advanced and see if that problem goes away.
thank you
