firewalls and bitcomet
It seems like nothing is actually downloaded. I don’t know too much about computers, but I’m guessing it has something to do with a firewall because I used Norton. Does anyone know what to do about this?
I have no clue what you are asking.
I have no idea what version of bit comet you are using, or if you are on a router, or what o/s you are using.
I also don’t know if you have correctly started a torrent file, or if it has any seeders?
the only thing I can get from your post is that you have one of many bit comet versions, and norton firewall.
If your not sure what info to put in your post, then put everything you can, like for starters, did you install bit comet? did you start a file.torrent… etc…
its better to post too much then not enoug info.
