My link
fix Score& title BUG
try this
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0
and change value 1200 from 3 to 1
[or
create txt file and rename it to score.reg and put those lines in to it
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones\0]
“2004”=dword:00000003
“2001”=dword:00000003
“DisplayName”=“Computer”
“PMDisplayName”=“Computer [Protected Mode]”
“Description”=“Your computer”
“Icon”=“shell32.dll#0016”
“LowIcon”=“inetcpl.cpl#005422”
“CurrentLevel”=dword:00000000
“Flags”=dword:00000021
“1200”=dword:00000001
or download attached fileScore.rar
Score.rar (637 Bytes)
Hi assem_hussein, this post has been forwarded to the development team.
My teammates will test this methos to see if this can solve other users issue as well.
Thank you so much for finding this method!
I tried the fix and it did not work hope there maybe other Ideas
Please don’t attempt a registry edit if your not confident in your abilities. An improper edit could make your system unstable.
Also, being that this specific bug has no effect on your downloading and is caused by an internet explorer setting or update, I recommend you let the development team do their work and evaluate this info rather then trying it yourself.
if you r using internet explorer 9 then u shud uninstall it… then make a new logon profile.. and delete the previous one…
and enjoy… dont try this regestry edit thing its bullshit
bug is fixed
