Folder System
Should Intreduce a Folder System so i can sort out all my files in to folders instead of looking through all my files for the one i need ie all kids movies under a folder called kids movies so i know were every thing is
Apologies for gravedigging but …
You can use Tags for each of the files then filter the task window using them.
