Format problems
Hey!
(Im new user of this program.)
I just dowload Medieval: Total War (Game) and i have this files in Medieval:Total War folder:
MEDIEVAL_TW_CD1.mdf.bc!
MEDIEVAL_TW_CD2.mds.bc!
MEDIEVAL_TW_CD3.mdf.bc!
MEDIEVAL_TW_CD4.mds.bc!
Tracked_by_Demonoid_com.txt.bc!
I don’t know much about format’s but i think *.mdf and *.mdf is a movie format’s… and bc! is propably BitComet format… Now. What i must do 2 play the game? Change format ?! On what ?!
Can somebody help me ?!?
the .bc means it is not yet complete, this will go when it is
the others are image files which you either burn to a cd or mount on a virtual drive using somethin like daemon tools
The “.mdf” is a disc image file. The “.mds” is the instruction file on how to use the .mdf file. So use a program like Daemon tools to mount the .mds file to a virtual drive or selct the .mds files to be burned to disc using a program like Imgburn.
