Hi, I am new to games downloads,The games that exist are iso’s can someone tell me how to use,install these files please.
Do i just use isobuster ect,or do i burn them to a disc with nero ect.
Any advice much appreiciated… ![]()
.iso is a disc image.
You can burn it with Nero, Alcohol 120, or any burning software.
You can also mount it in a virtual cdrom drive with alcohol or deamon tools.
[so I just mount it to a cdr ect and then autoplay it in drive yes
no two games install exactly the same, but your question was regarding .iso files.
you can EITHER burn, or mount (virtual cdrom drive, no accual disc or drive exsists).
It is not possible to instruct you on how to install every game made.
Many Thanx I have sussed it now Cheers again
