Hi there.
First of all - to BC Development Team - thank you guys. You make my favourite BT client ![]()
Surely, it’s not perfect software, but what is?
Well, here are some things I think need to be reconsidered…
Each time I start BC, I have to re-set priorities of my tasks. You see, I have some seeding tasks that should use more traffic then other. I use up/down limits in such cases, so this isn’t critical. Not that I start BC very often, but I have lots of tasks. Nevertheless - if option is there - it must either work or be removed.
Chat behaves odd. Even if someone is shown to be there (e.g. “Chat(1)”), I can see no one in user list. Older versions sometimes showed numbers instead of names there, but now chat seems to be degrading…
Sometimes all peers in active torrent’s “Peers” disappear. Yet I still upload to them (~5-10 kB\s - most my torrents are slow - and speed varies). Right now I don’t remember what “Seed/Peer[all]” says in these cases, but traffic goes out, that’s for sure.
“Logs” have no scrolling. Often I come back after week-end spent elsewhere, and I want to check whether my ISP has given me all possible “outer” IPs from it’s own xx.xx.xxx.100-199 or 200-254 or something like this ![]()
Trackers of active (and most likely, stopped) task are sorted only in order of adding. E.g. you can’t easily add 4th tracker and later switch trackers in list from 1-2-3-4 to 3-1-4-2 order. And it’s tricky to add “|” to mirror tracker, if you haven’t done this on adding both of them.
Why would I need this? Some sites count U/D ratio from the first tracker in .torrent’s list only - and if their own tracker is 2nd there I get no ratio change on such site. I should be able to save .torrent with needed tracker first in list.
Tracker cannot be contacted separately - only all of them at the same time (for each multi-tracker torrent). Of course, this can be used to hammer selected victim - but now only all of trackers can be hammered.
Because of my dynamic IP I have to log in private tracker’s site before starting task or I’ll get an error message. BC stops contacting this tracker in this case, and I have to “Manual Connect” to all trackers instead of one private after visiting tracker’s site.
I use WinXP Pro SP2 Corp. with 320kbps Cable connection to Internet; I’m behind my ISP’s NAT and it keeps changing my “outer” IP-address 1-2 times per hour. My system (and BitComet) is online 24/7 (except rare crashes %) ).
Anything else I find concerning BC’s GUI will be posted in this thread later.
I hope I help you make BC even better than it is now - with what I can. Best regards!
P.S. Of course, I’m using latest available BitComet - v.0.68 (as of this post’s date).
