i try to port mapping as in the faq. but still i can not get the ‘remote’ peers.
here is the bitcomet log:
Windows XP ICF Status: Firewall TCP port is opened.[Local Area Connection]
Windows XP ICF Status: Firewall UDP port is opened.[Local Area Connection]
Windows XP WF Status: TCP Port is opened in Windows Firewall.
Windows XP WF Status: UDP Port is opened in Windows Firewall.
Update Local IP: 192.168.1.2
Windows XP ICS Status: cannot find working ICS.
Windows XP UPnP Status: device not found!
UDP tracker report: WAN IP = 60.x.x.x
Connected to UDP helper tracker on 2006-10-29 00:03
why is the UPnP stated that the device is not found?
please help me…
Please read this article to understand why the device is not found.
http://support.microsoft.com/kb/886257
Now, follow these steps to solve your problem:
Test your port on www.canyouseeme.org If its positive then follow the next step. If its negative then u need to forward the port on your router. Please have a look at the portforwarding settings available on this forum for your router. Once ur port is successfully forwarded in ur router, follow the next step.
Disable Windows Firewall & connect to BitComet again. U will definitely see a change in Windows XP UPnP status.
Now, disconnect BitComet (At this point, I assume that Windows Firewall is Turned OFF). Now, visit http://support.microsoft.com/kb/886257 and follow Method 2. Its more easy. Once you see the Default Gateway, close that window. Turn On Windows Firewall. Connect to BitComet and try downloading any torrent. Is your problem solved? Has your download speed increased?
It solved my problem. Wait for at least half hour to see a massive difference in downloading speed. After starting Bit Comet again, you will see the following changes in the Log file of the torrent:
Update Local IP: ***********
Windows XP ICS Status: TCP PortMapping Failed.
Windows XP ICS Status: UDP PortMapping Failed.
Windows XP UPnP Status: Found WAN Connection Device [*******, Inc.]
Windows XP UPnP Status: Found Service: WANIPConnection
Windows XP UPnP Status: WAN IP: ***********
Windows XP UPnP Status: TCP Port Mapping Existed!
Windows XP UPnP Status: UDP Port Mapping Existed!
DO NOT BOTHER about ICS status. Please read this article before you really start thinking about it.
http://windowshelp.microsoft.com/Windows/e…2b14771033.mspx
Now, ask yourself, do you really want ICS?? If no, then ur done. If yes, then search for ICS configuration (for Windows XP) on www.microsoft.com
Gud Luck!!
