hi, when i put only ONE backup tracker, work good, but when put more trackers in the list it say Q0 Waiting
and keep doing that.
How must i write the backup trackers in the list?? (can be that??)
I dont know what to do..
Please helpme
Bye
From Argentine!
Please use the edit function to add additional info to a post you have made.
Regarding Bit Comet version .60, we request that you not use that version due to a problem it has with private trackers. version .70 is our latest “stable” release. We don’t recommend any versions before .64.
I suggest you try one of these newer versions and report if you still have the problem.
Add the pirate bay’s tracker as a back up and you should be fine and just use DHT.
yes i supose that the new versions of Bitcomet maybe dont have that error or some, but i use Bitcomet 0.60 because is the only version that work fine, it download at 100kb i have a 128kb connection.. is very good the download and with the others version i try all is low the down rate.
