Help a poor noob..
Where do I find, and how do I use private trackers >___>
Private Trackers are usually not given publicly. Rather when you upload a torrent, the torrent search engine itself will add the tracker into your torrent.
So…you can try:
www.isohunt.com
www.torrentspy.com
www.mininova.org
Most search engine sites will have their own trackers. If however you want to use a tracker without registering at the search engine site, try this tracker out:
http://tracker.prq.to/announce
That tracker is for the Pirate Bay, they are down at the moment.
