Help Can I make backup of half dwlded movies so that I can format C: drive
I downloaded 4 movies each downloaded more than 50% through bitcomet & then needed to format C:
drive so copied these 50 % movies from bitcomet folder to F: . Then formatted C: installed bitcomet then
copied that backup movies again to bitcomet folder but didn’t work.
So, plz help me i still have backup of those movies.
follow the link for clean install just for info. you should firts ask and then format.
when open the BC do you see your tasks there in the list? If yes mark them right-click->maual hash check.
