it suppost can finish like few mins..bt i already waited 4 haf hr n it still de same??
n i cant open de file cuz still need 0.4% to finish…
wat should i do to fix de /torrent/ or de /file/?
i tried to close bitcomet n restart de pc bt doesnt work
wats wrong wif it??
well, i donno what is going wrong. But i do have this kind of situation too, i will just stop downloading and rename the file to the file format it should be. What file you downloading? Movie? if So change to something like .avi and .exe if it is a executable file. it work for me.
wats wrong wif it??
Regarding your post.
If a member doesn’t understand the english language, we try to help them the best we can.
I however feel you are posting in broken english because perhaps you think it is cool, or fun, but it is NOT.
We have members from all over the world visiting here, and most will have no idea what you are saying.
If you continue to post this way, your posts will be deleted without comment.
Now, regarding your problem. It could be an issue with your router having gaming mode enabled. This sometimes rewrites internal IP addresses causing certain pieces of data to fail hash check, therefore neer finishing.
