PLz help me I have found myself waiting 5 days for this and am interested in gettin it to work but I received this message..winrar diagnostic stating that its corrupt but it could have been my fault tryin to extract it all at once plz look into it ty
http://isohunt.com/torrents.php?ext=&o…marvel+alliance
BIGpimp
I’m not sure which one of those torrents you downloaded.
If it is a multiple part .rar, then you only need to start the first piece.
If winrar says the archive is corrupt, then you can try running a manual rehash, which will repair any pieces that were damaged during or after download, but if the torrents maker uploaded a bad piece, this won’t help.
Winrar does have an archive repair tool, but it has limited sucess rate.
BIGpimp
how do i do a manuel repair??
I suggested you do a manual rehash of the files, in bit comet, before you attempt to repair the archive in winrar.
