help!! instaling this
how am i supose to this for age of empires3 war chiefs some walk me through this … 4. Copy the cracked files located in the Crack directory on the CD to your
 installation directory.
how do i do that???
look on your cd in a folder/directroy named “crack”
Copy those files onto your hard drive, to the folder you selected when you installed the program.
Do you know how to copy files?
yea but it never asked wat file i should save it on it goes straight to instaling. wat should i do?
wait since its an expansion should i put the crack in the original game?
the file/s in the crack directory should have the same name as the one your replacing.
I suggest you rename the current file, then copy the crack file.
Example
orignal file file.exe rename to file.xxx
cracked file file.exe copy to where the first file.exe was located.
yea but wat file am i supose to replace there is no file for the expansion im installing i cant find it it never asked me when im installing the expansion the name of the file and when copy the crack file into the original ageofempires 3 i try to that the expansion from the crack file and it tells me that the rockall.dll was not found wat does that mean. this is so confusing ive never had this problem before
I assume there are one or more files inside the “crack” folder.
Copy those files into the directroy/folder where you installed it.
This is not complicated, so I have no idea why you are having trouble?
