I am at the point of pulling my hair out trying to fix this! I have tryed everything and now i just need some 1 on 1 help becuse nothing else is working! i have bitcomet .70
I have a speedstream DSL (modem only, altho i did for some time have a router but i dont use it anymore..) I have zone alarm with the firewall turned off and widows firewall tuned off
I have avast and i use winxp sp2! canyouseeme.org cant see me and i am going crazy! iv tryed everything!! i have tryed to use a static ip, portforwording, normal without any staic, proxy for a little while (not sure it worked tho)
Please help me, I get onyl local and sometimes NAT travelsal, DHT works for me and trackers work with me. i have never gotten a dl speed of 100/kb or higher, if you need any info i will give it and if you have any idea of a way to help me please tell me!
It’s 3:10 am and your post hurts my eyes. So I am doing some miner editing, especially to that title of “HELP! local but no remote!, AHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!”
Then I will try to make sense and help you.
I have a speedstream DSL modem
What version do you have? Have you updated the firmware at all?
What is the point of having firewalls if you have them both turned off? First get rid of Zonealarm. It’s junk and it’s probably adding to your problems. For now just turn the Windows Firewall back on with exceptions allowed and let BitComet add your ports to it.
Are they fully updated?
Did you have BitComet running when you tried their site?
If you only have a speed stream modem running then you don’t need to do any of this. Since that’s a modem its not even possible to portforward.
Just set Windows Automatically Obtain an IP address and you should be fine. If you’re only running Windows Firewall then read our settings guide to make sure BitCoemt will add it’s ports automatically. Also, make sure the .torrents you’re running aren’t dead. Meaning their health is above 100%.
i guess you are one of the victim of ISP throttle bitcomet user…you might just have to wait for the new announcement then.
