i downloaded eudemons online off of bitcomet 0.70 and i pressed save torrent as and then i dont know what to do and if that’s not it plz tell me what i do for games from bitcomet i am just confused help me plz!!
I’m not exactly sure what your asking here.
Have you read the posts on installing and using bit comet?
Or are you wanting us to explain the whole procedure here in a reply to your post?
Have you installed bit comet?
Have you ran the torrent file you downloaded?
I suggest you begin by learning alittle about bit torrent protocall…
http://en.wikipedia.org/wiki/Bittorrent
and read the posts in this forum so you will have some understanding of how this works, and know what you need help with.
if you have saved the torrent on a folder, that wont make the files start downloading.
you have to open the file using BitComet (at the top, there is a button saying “Open”).
once you select the torrent file that you saved, bitcomet will start downloading it
