Help me please
Default tracker optimization rules file loaded.
IP rules file: ipfilter.dat loaded, 0 entries.
Start Listening at TCP Port:18037
Start Listening at UDP Port:18037
BitComet 0.70 is running on:
CPU : Intel® Celeron® M processor 1.50GHz 1496 MHz
RAM size : 502.42 MB
OS Version: Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
Windows XP ICF Status: Firewall TCP port is opened.[Local Area Connection]
Windows XP ICF Status: Firewall UDP port is opened.[Local Area Connection]
Windows XP WF Status: TCP Port is not opened in Windows Firewall.
Windows XP WF Status: add TCP port in Windows Firewall Succeed.
Windows XP WF Status: UDP Port is not opened in Windows Firewall.
Windows XP WF Status: add UDP port in Windows Firewall Succeed.
Windows XP ICS Status: cannot find working ICS.
Favourite sites file version checking . . . . up-to-dated now.
Preview_ad file version checking . . . . up-to-dated now.
Windows XP UPnP Status: device not found!
I already set my conection settings
Upload speed onlydownloading 1 torrent but when i check the peers there are local so when i check my port
i says stealh or something like that f no says operation timed out thatmos be my modems firewall maybe its a speedtouch 530 i dont know how to see th modems settings. Or if you think the problem is another thing any help is greatly appreaciate. Sorry for my bad english i an puertorican and i live in puerto rico. thx in adv
For the port issues, it’s telling you
I Found a Problem
I fixed the problem.
For the UPnP and ICS issues, Google is your friend. (What is ICS? Should you care about it? What’s a UPnP device? Do you have any?)
The lack of remote connections indicates that you have a firewall blocking your listen port (or have set it to NO LISTEN PORT).
The speedtouch 530 is a combination router and modem. That’s important because most plain modems do not have built-in firewalls and don’t need to be configured. Yours, being a router too, does.
The owners manual will tell you how to access its configuration software. Your first step should always be to read the manual. You can find specific instructions for yours and for most other common routers, at www.portfoward.com
