Help me
i have downloaded a file from torrentspy.com . Example : namefile.daa . I cant open it . what shoud i do ?
do you mean you have opened a torrent? or the torrent has finished downloading??
if you cant open the torrent, just ‘save as’ the file and then open it with BitComet
if you cant open the finished file, you may just be doing something commonly wrong. right click on the finished file in bitcomet, select ‘browse downloaded directory’ and the file that shows is the file you open
.daa files (direct access archive) are made using “powerISO”
It is basically a “disc image”, which can be burnt to disc, or mounted in virtual cdrom drive.
You can download a trial version direct from them.
Google can find it for you.
ps. there are many working keygens availble on torrent sites for this as well.
To be more precise this is a compressed disc format the PowerISO came up with. UltraISO can also read this, and is probably the better program to go with because it supports more formats.
