help me
i have a file namefile.daa . how to convert it from daa to file.iso
You should try using PowerISO, or UltraISO. But there is a little problem. Unregistered version of these programs allows you to modify/extract files up to 300mb. If your file is bigger, try looking for serial/crack. Be careful though, because owners of such sites like to place p*** banners.
PowerISO 3.3 Trial
UltraISO Trial
