i have download pianofx from torrentspy.com . can you give me serial number
Look in the download for a readme or a .nfo file. Open .nfo files with either notepad or wordpad.
where is it . i dont see
We have no idea what you downloaded, and you havn’t identified the files in your download, so we have done the only thing we can, is to tell you what kind of files are often included with torrent downloads.
If you had identified the torrents full name, and a complete list of the files (including extensions), then we may be able to offer better advice.
