i ccan’t change mpcstar with gomplayer
What is your question, and how does this relate to bitcomet?
The only thing you can change about this in BitComet is to change the “Preview” player. To do that open the “Options” or “Prefferences” menu(depending on your version of BitComet) in the “Advanced” tab and set “ui.preview_program_path” to the .exe file of your player. For the “Play” option you must look in the player’s settings for it’s assigned file types setup; or in the video file’s proprieties window, where it says “Opens with” click the “Change…” button and select or browse for your desired player.
