Help Newbie problem
I am new to torrants and BitComet and have learned a lot from the folks on here. I have 1 problem I can not figure out. The files look great on my computer but when I play them on my DVD player they Pixellate badly. I am playing the disk on a Samsung DVD-R135 DVD recorder and viewing it on a Westinghouse LVM-37W3 37"LCD. I have tried the disk on a cheap a DVD player and a 32" TV and the picture looked fine. The files were all downloaded with BitComet and put on disk with DIVX PLAYER 6.0. What can I do to improve my picture? Thank you much for your help.
That unit has an unfortunate reputation. The big question is, how did you burn the disk? The Samsung seems to rather dislike disks that it doesn’t burn itself, while everything else dislikes the disks it burns. This may not be a readily solveable problem.
It also has nothing to do with BitComet, so is being asked in the wrong forum.
Moved to the proper section.
Yeah, basically DVD Recorders do not play burned discs well or have other problems. Old junk will play my burns where my Uncle’s DVD Recorder that he just had to have has a lot of problems.
