Hi,
I’ve download a film but it’s split into 2 avi files, is there anyway of convert the two files into 1? ![]()
Hi,
windows movie maker will do it
and there are many other programs too, the list is endles, go here
http://www.videohelp.com/tools?s=108#108
Virtual dub is another
the best is camstasia studio
you can even make it smaller if you need to’
Your reason for doing this could make a huge difference in what to recommend. If you just want to past them together (why?), that’s a whole lot different from, say, trying to fit them onto a single disk, which would involve shrinking, and maybe converting. OTOH, maybe you don’t need to join them to achieve whatever you’re trying to do.
