help please
ive had loads of people help me out with this problem but its still happening
basically iv download wrestlemania 1 and want to convert and burn
but no matter what program i seem to use as soon as i put the file into the program the program crashes and goes off in a second
can anyone please help
thanks jim
I’m not sure why your video is crashing your encoding software.
Some obvious things to check is that you have a computer that meets the minimum specs to run the program.
Also, if you havn’t done so, you may have to update your codecs.
Our admin here recommended k lite codec pack, and I have had countless people use it and not one bad report (except from other members here)
although I think this is just because they prefer a different pack.
here is link…
http://www.free-codecs.com/download/K_Lite_Codec_Pack.htm
this pack is updated regularly and should contain any codecs you could need. (I recommend installing the default settings only)
ps. I would also confirm that this file plays on your pc, as a corrupt file will never reencode to something worth watching.
