HELP !! PLEASE
:mellow: just wondering when download is complete … how do you go about actually playing the torrent ? as the preview doesn’t work and also would anyone care to answer this question … after download is complete … do you have to let the torrent upload aswell and if so then how long for
if a torrent is a movie and the bittcomet previwer doesn’t work you could use vlc media player…(that’s the best one there is)… or if you downloaded the torrent you could “open it” by pressing open dir after you selected the torrent… after download you have to let him upload as well till you reach 1.1 ratio in bittcomet that part is called U/D ratio..
If you have problems using the files you downloaded, the please include a complete file list (with extensions) of what you downloaded.
Adding a link to where you downloaded the torrent would be a good idea too. Also, this wouldn’t be a bit comet question, so please post that question in the proper area.
Please do not duplicate posts.
You just asked the same questions here:
http://forums.bitcomet.com/index.php?showtopic=4611&hl=
… and less than one hour later, you ask again.
cassie
