i just downloaded bitcomet and whenever i try to download an album torrent or whatever, it doesnt download and it stays at 0%. under status it says connecting and it never connects. whats the frikin problem?
The one thing I can think of is that the tracker that torrent uses is a bad one. Try using google to find the same file somewhere else and look to make sure that the file has more than 10 seeds
Don’t waste your time with google. For starts try this .torrent search engine: www.torrentz.com.
If your gonna use torrentz.com
then make sure you also have Peer Guardian 2
cause whenever I use torrentz.com i get tons of MediaSentry hits in pg2
