Have extracted all the files and installed fifa06, problem is when i click on the icon to start the game it says i must insert CD… how do i over come this??
Cheers
PJ
Cheers
PJ
You fine a “no cd crack.”
These are often included with the files you downloaded.
Look for a “file.nfo” or readme file and open either in notepad, there should be instructions for installing and using the game.
