Help understanding an option needed
What does the Set hash check thread to low priority option mean exactly?
Performing a hash-check is a very CPU-intensive operation and can interfere with other processes. If getting the check done is less important to you than those other processes, then you can set it to a lower priority so it doesn’t interfere so much.
