help!!!!
:frowning: after selecting subject to download and getting the download screen, the next screen just shows gibberish,
I have downloaded before with bitcomet so why is this happening now??
many thanks for any help.
Bryan.
could you do a print screen of what you mean?
Bryan.
Hi, this is the screen I get when I hit the download button on any subject, avi,mp3, tv, whatever, instead of the usual save/run/etc I used to get.
I was asked to download languages, but said no.any clue.
I can use other portals to download eg. Torrentportall.
again thanks for your intrest and help.
Bryan.
ÎÞ·¨ÕÒµ½¸ÃÒ³
ÄúÕýÔÚËÑË÷µÄÒ³Ãæ¿ÉÄÜÒѾ­É¾³ý¡¢¸üÃû»òÔÝʱ²»¿ÉÓá£
Çë³¢ÊÔÒÔϲÙ×÷£º
È·±£ä¯ÀÀÆ÷µÄµØÖ·À¸ÖÐÏÔʾµÄÍøÕ¾µØÖ·µÄƴдºÍ¸ñʽÕýÈ·ÎÞÎó¡£
Èç¹ûͨ¹ýµ¥»÷Á´½Ó¶øµ½´ïÁ˸ÃÍøÒ³£¬ÇëÓëÍøÕ¾¹ÜÀíÔ±ÁªÏµ£¬Í¨ÖªËûÃǸÃÁ´½ÓµÄ¸ñʽ²»ÕýÈ·¡£
µ¥»÷ºóÍ˰´Å¥³¢ÊÔÁíÒ»¸öÁ´½Ó¡£
HTTP ´íÎó 404 - Îļþ»òĿ¼δÕÒµ½¡£
Internet ÐÅÏ¢·þÎñ (IIS)
¼¼ÊõÐÅÏ¢£¨Îª¼¼ÊõÖ§³ÖÈËÔ±Ìṩ£©
תµ½ Microsoft ²úÆ·Ö§³Ö·þÎñ²¢ËÑË÷°üÀ¨“HTTP”ºÍ“404”µÄ±êÌâ¡£
´ò¿ª“IIS °ïÖú”£¨¿ÉÔÚ IIS ¹ÜÀíÆ÷ (inetmgr) ÖзÃÎÊ£©£¬È»ºóËÑË÷±êÌâΪ“ÍøÕ¾ÉèÖÔ¡¢“³£¹æ¹ÜÀíÈÎÎñ”ºÍ“¹ØÓÚ×Ô¶¨Òå´íÎóÏûÏ¢”µÄÖ÷Ìâ¡£
i got the same problem too
It could well be a misconfigured web server, and it’s trying to send you the file contents as an HTML page, which won’t work. You might try the site with a different browser to see if you get the same result, just in case it’s your browser mishandling the download.
hi, thanks for the interest, but if it is a web server would it happen with every download on
Bitcomet ? and why is torrent portal ok ?
If it is the web server, depending on exactly what’s wrong with it, then it would happen to any browser, for any user visiting that particular torrent site. Other sites wouldn’t be involved, nor would any client software.
