Help
ive somehow managed to delete my unistall option on bitcomet 0.67 how do i go about unstalling it?
You can go to control panal, “add and remove programs”
“your uninstaller” is also a good program for this.
also, there is a program that “dark shroud” (staff member here) recommends, I’m sure he will find this post within the next day or so.
i havent got it in add or remove programs and i dunt know what or where that 'your unistaller’is
could ur other admin hook me up with something 2 unistall it plz
its jus i want to upgrade to the newer version
here is some info on “your uninstaller”
Your Uninstaller <— click me
You could also find it on many torrent sites (not that I would recommend downloading pirated software) hehehe…
ps. many people install the newer version on top of exsisting version, but I prefer to remove the old versions of programs before installing new versions when possible.
A good program for you to try is CClener.
well ive downloaded both them apps u said n neither could find them so i thought sod it and tryed to jus install the new version but it wudnt let me
bump
When you try to install v0.70 does any error message pop up?
